    Quelle: Mauszeiger Explosion mit Grafik
    Quelle: Feuerwerk v2
    Quelle: Fliegender Santa
    • WoltLab Suite 5.4.9
    • WoltLab Suite 5.3.15
    • WoltLab Suite 5.2.16
    • WoltLab Suite 3.1.24
    How to Apply Updates
    • Empty blogs are no longer listed in the sitemap. 5.4 5.3
    • A display error of the calendar weeks was corrected. 5.4
    • The license confirmation will now be prompted again after one day. 5.4
    • The checkbox for disabling/approving reviews when creating and editing files is no longer displayed when reviews are disabled. 5.4
    • Embedded objects in descriptions of file versions were not loaded. 5.3
    • When approving posts, the starting post stored in the thread is now updated correctly. 5.4 5.3
    • Merging deleted threads will no longer cause incorrect updates to the board statistics. 5.4
    • Reactions details of posts can now be viewed correctly in the article view when discussion topics are enabled. 5.4 5.3 5.2
    • vBulletin 5.x
      • The import of BCrypt passwords has been fixed.
    WoltLab Suite Core: WebAuthn
    • Updated some external libraries. 5.4
    • Tables were not always processed correctly when inserted into the editor. 5.4
    • The behavior of the editor after submitting a post was fixed for Opera Mobile. 5.4
    • Auto-completion, e.g. for usernames, sometimes displayed excluded or already selected entries. 5.4
    • Displaying different content types on one page no longer causes problems when quoting. 5.4
    • Deletion of content with reactions of deleted users could fail due to a bug in MySQL 8.x. A workaround for this error message has been integrated. 5.4
    • Rich embeds are no longer converted to signatures. 5.4
    • Timeouts when reading the response of the source server in ImageProxy and rich embeds no longer lead to an error message. 5.4
    • Added support for embedding private Vimeo videos. 5.4
    • An existing block of now unblockable users can now be unblocked in the user profile. 5.4
    • The new request for the confirmation code for an e-mail change is no longer incorrectly rejected with a message that the user is already activated. 5.4 5.3 5.2 3.1
    • When sending e-mails via PHP, e-mail headers are now also converted to "canonical" notation instead of being entirely lowercase. This avoids problems with email servers that insist on a certain spelling, contrary to the email standard. 5.4
    • The acpSimple template has been aligned between frontend and ACP. 5.4
    • The preview in the administration interface now works even if the article BBCode is used in the content. 5.4
    • The incorrect spacing at the bottom of the page when displaying full-screen dialogs (for example, the display of responding users) under iOS 15 is now suppressed. 5.4
    • The tooltip for links in the editor on small screens was sometimes positioned incorrectly. 5.4
    • When editing links in the editor sometimes the existing link was not edited. 5.4
    • Message editing options were positioned too far up on small screens. 5.4
    • The loading indicator for background requests ("AJAX") is now displayed correctly even after a failed request. 5.4 5.3 5.2 3.1
    • When signature images are scaled due to the maximum height setting, the aspect ratio is now preserved. 5.4
    • The names of authors in the listing of articles are no longer linked. In practice, the links were only accessible via the keyboard, because the entire space is a link to the article. 5.4
    • The display of code boxes inside citations was corrected. 5.4
    • Fixed a visual bug that became visible when not all items in the main menu can be displayed. 5.3
    • Form Builder: When resetting a form, the values for ACL permissions were not cleared. 5.3
    • For developers: Session::getDeviceIcon() is now deprecated. 5.4
    • For developers: The PHP-based DDL API now rejects indices with duplicate columns. 5.4
    • For developers: The PHP-based DDL API could reject valid changes as invalid under certain circumstances. 5.4
    • For developers: The UserFormField can now be initialized with IDs of non-existent users without causing an error message. This especially affects the processing of data where null is stored as userID. 5.4
    Quelle: https://www.woltlab.com/commun…4-9-5-3-15-5-2-16-3-1-24/
    • Leere Blogs werden nicht länger in der Sitemap aufgelistet. 5.4 5.3
    • Ein Anzeigefehler der Kalenderwochen wurde korrigiert. 5.4
    • Die Zustimmung zur Lizenz wird jetzt nach einem Tag erneut abgefragt. 5.4
    • Die Checkbox zur (De)aktivierung von Rezensionen beim erstellen und bearbeiten von Dateien wird bei deaktivierten Rezensionen nicht mehr angezeigt. 5.4
    • Eingebettete Objekte in Beschreibungen von Dateiversionen wurden nicht geladen. 5.3
    • Bei der Aktivierung von Beiträgen wird der im Thema hinterlegte Startbeitrag jetzt korrekt aktualisiert. 5.4 5.3
    • Bei der Zusammenführung von Themen werden bereits gelöschte Themen nicht mehr in der Statistik abgezogen, da diese bereits bei der Löschung abgezogen wurden. 5.4
    • Die Reaktions-Details von Beiträgen können nun korrekt in der Artikel-Ansicht eingesehen werden, wenn Diskussionsthemen aktiviert sind. 5.4 5.3 5.2
    • vBulletin 5.x
      • Der Import von BCrypt-Passwörtern wurde korrigiert.
    • Aktualisierung der mitgelieferten externen Bibliotheken. 5.4
    • Tabellen wurden beim Einfügen in den Editor nicht immer korrekt verarbeitet. 5.4
    • Das Verhalten vom Editor nach Absenden eines Beitrags wurde für Opera Mobile korrigiert. 5.4
    • Die Autokomplettierung, etwa für Benutzernamen, hat unter Umständen ausgeschlossene oder bereits ausgewählte Einträge angezeigt. 5.4
    • Die Anzeige unterschiedlicher Inhaltsarten auf einer Seite führt nicht mehr zu Problemen beim Zitieren. 5.4
    • Die Löschung von Inhalten mit Reaktionen gelöschter Benutzer konnte aufgrund eines Fehlers in MySQL 8.x fehlschlagen. Ein Workaround für diese Fehlermeldung wurde integriert. 5.4
    • Rich Embeds werden nicht länger in Signaturen umgewandelt. 5.4
    • Timeouts beim Lesen der Antwort des Quellservers im ImageProxy und bei den Rich Embeds führen nicht mehr zu einer Fehlermeldung. 5.4
    • Eine Unterstützung für das Einbetten privater Vimeo-Videos wurde ergänzt. 5.4
    • Eine bestehende Blockierung von mittlerweile nicht mehr blockierbaren Benutzern kann jetzt im Benutzerprofil aufgehoben werden. 5.4
    • Die erneute Anforderung des Bestätigungscodes für eine E-Mail-Änderung wird nicht mehr fehlerhaft mit einer Meldung abgelent, dass der Benutzer bereits aktiviert sei. 5.4 5.3 5.2 3.1
    • Beim Versand von E-Mails über das PHP-Verfahren werden E-Mail-Header jetzt ebenfalls in die „kanonische“ Schreibweise überführt, anstatt komplett aus Kleinbuchstaben zu bestehen. Dies umgeht Probleme mit E-Mail-Servern die entgegen des E-Mail-Standards auf eine bestimmte Schreibweise bestehen. 5.4
    • Das acpSimple-Template wurde zwischen Frontend und ACP angeglichen. 5.4
    • Die Vorschau in der Administrationsoberfläche funktioniert jetzt auch dann, wenn im Inhalt der Artikel-BBCode genutzt wird. 5.4
    • Der fehlerhafte Abstand am unteren Ende der Seite bei der Anzeige von Vollbilddialogen (beispielsweise die Anzeige der reagierenden Benutzer) unter iOS 15 wird jetzt unterdrückt. 5.4
    • Der Tooltip für Links im Editor auf kleinen Bildschirmen wurde manchmal fehlerhaft positioniert. 5.4
    • Beim Bearbeiten von Links im Editor wurde manchmal nicht der bestehende Link bearbeitet. 5.4
    • Die Bearbeitungsoptionen für Nachrichten wurden auf kleinen Bildschirm zu weit oben positioniert. 5.4
    • Der Lade-Indikator für Hintergrund-Anfragen („AJAX“) wird jetzt auch nach einer fehlgeschlagenen Anfrage korrekt angezeigt. 5.4 5.3 5.2 3.1
    • Wenn Signatur-Bilder aufgrund der Einstellung zur maximalen Höhe skaliert werden, dann bleibt das Seitenverhältnis jetzt erhalten. 5.4
    • Die Namen der Autoren in der Auflistung von Artikel werden nicht mehr verlinkt. Die Links waren in der Praxis nur über die Tastatur erreichbar, da die komplette Fläche einen Link auf den Artikel darstellt. 5.4
    • Die Darstellung von Code-Boxen innerhalb von Zitate wurde korrigiert. 5.4
    • Es wurde ein visueller Fehler behoben, der sichtbar wurde, sobald nicht mehr alle Einträge im Hauptmenü angezeigt werden können. 5.3
    • Form-Builder: Beim Zurücksetzen eines Formulars wurden die Werte für ACL-Berechtigungen nicht gelöscht. 5.3
    • Für Entwickler: Session::getDeviceIcon() ist jetzt deprecated. 5.4
    • Für Entwickler: Die PHP-basierte DDL-API lehnt jetzt Indices mit doppelten Spalten ab. 5.4
    • Für Entwickler: Die PHP-basierte DDL-API konnte unter Umständen gültige Änderungen als unzulässig ablehnen. 5.4
    • Für Entwickler: Das UserFormField kann jetzt mit IDs nicht-existenter Benutzer initialisiert werden, ohne, dass es zu einer Fehlermeldung kommt. Dies betrifft insbesondere die Bearbeitung von Daten bei denen null als userID gespeichert ist. 5.4
    • vBulletin 5.x
    Quelle: https://community.woltlab.com/…4-9-5-3-15-5-2-16-3-1-24/
    Quelle: https://www.woltlab.com/pluginstore/file/7097-pelikan/
    Quelle: https://pluginstore.woltlab.com/file/7097-pelikan/
    Quelle: https://www.woltlab.com/plugin…le/7093-minecraft-linker/
    Quelle: https://www.woltlab.com/plugin…ile/7091-moderationsbuch/
    Quelle: https://pluginstore.woltlab.com/file/7091-moderationsbuch/
    Quelle: https://www.woltlab.com/plugin…le/7089-fliegender-santa/
    Quelle: https://pluginstore.woltlab.com/file/7089-fliegender-santa/
    Quelle: https://www.woltlab.com/plugin…basic-core-branding-free/
    Quelle: https://pluginstore.woltlab.co…basic-core-branding-free/
    Quelle: https://www.woltlab.com/plugin…-basic-core-dark-edition/
    Quelle: https://pluginstore.woltlab.co…-basic-core-dark-edition/
    Quelle: https://www.woltlab.com/plugin…basic-core-light-edition/
    Quelle: https://pluginstore.woltlab.co…basic-core-light-edition/
    Quelle: https://www.woltlab.com/plugin…cketsystem-e-mail-import/
