    Quelle: https://www.woltlab.com/commun…nd-neue-zusatzleistungen/
    Quelle: https://community.woltlab.com/…nd-neue-zusatzleistungen/
    Quelle: https://www.woltlab.com/pluginstore/file/7075-bats/
    Quelle: https://pluginstore.woltlab.com/file/7075-bats/
    Quelle: https://www.woltlab.com/plugin…y-projekte-branding-free/
    Quelle: https://pluginstore.woltlab.co…y-projekte-branding-free/
    Quelle: https://www.woltlab.com/plugin…entwickler-shunting-yard/
    Quelle: https://pluginstore.woltlab.co…entwickler-shunting-yard/
    Quelle: VieCode Filebase Slider
    • WoltLab Suite 5.4.8
    How to Apply Updates
    • The import of blogs now supports cover photos. 5.4
    • (Non-functional changes for technical reasons only.) 5.4
    WoltLab Suite Calendar: Event Threads
    • Embedded objects in descriptions of file versions had not been loaded. 5.4
    • The mobile view of the thread list could display incorrect cached values for the thread starter. 5.4
    • User signatures were not displayed below messages. 5.4
    • Resolved an issue that caused an error when viewing the list of attachments. 5.4
    • Invision Community 4.x
      • Added support for the import of the blog and gallery. 5.4
      • Incorrect handling of URL placeholders in messages. 5.4
    • Resolved an issue that caused an incorrect report that the session was expired on form submit. 5.4
    • Resolved an issue that caused the setup to fail when using an unencrypted http connection. 5.4
    • Improved the message when encountering an invalid XSRF protection token. 5.4
    • Resolved a compatibility issue when running under PHP 8.1. 5.4
    • Fixed a visual artifact when the main menu starts overflowing. 5.4
    • Resolved an issue when using the ancient mysql extension instead of mysqlnd (MySQL Native Driver). 5.4
    • Form Builder: Resetting a form did not clear the values for ACL permissions. 5.4
    • Dev Tools: The standalone flag for instructions was not applied correctly. 5.4
    Quelle: https://www.woltlab.com/commun…date-woltlab-suite-5-4-8/
    • Der Import von Blogs unterstützt jetzt Titelbilder. 5.4
    • (Nicht-funktionale Änderungen aus rein technischen Gründen). 5.4
    • Eingebettete Objekte in Beschreibungen von Dateiversionen wurden nicht geladen. 5.4
    • Die mobile Ansicht der Themenliste konnte falsche zwischengespeicherte Werte für den Themenstarter anzeigen. 5.4
    • Die Signaturen von Benutzern wurden nicht unter Nachrichten angezeigt. 5.4
    • Es wurde ein Problem behoben, das bei der Anzeige der Liste der Dateianhänge einen Fehler verursachte. 5.4
      • Unterstützung für den Import von Blog und Galerie hinzugefügt. 5.4
      • Fehlerhafte Behandlung von URL-Platzhaltern in Nachrichten. 5.4
    • Es wurde ein Problem behoben, das zu der falschen Meldung führte, dass die Sitzung beim Absenden des Formulars abgelaufen sei. 5.4
    • Es wurde ein Problem behoben, das dazu führte, dass die Einrichtung bei Verwendung einer unverschlüsselten http-Verbindung fehlschlug. 5.4
    • Die Meldung beim Auftreten eines ungültigen XSRF-Schutz-Tokens wurde verbessert. 5.4
    • Es wurde ein Kompatibilitätsproblem bei der Ausführung unter PHP 8.1 behoben. 5.4
    • Es wurde ein visueller Fehler behoben, der sichtbar wurde, sobald nicht mehr alle Einträge im Hauptmenü angezeigt werden können. 5.4
    • Ein Problem bei der Verwendung der veralteten mysql-Erweiterung anstelle von mysqlnd (MySQL Native Driver) wurde behoben. 5.4
    • Form-Builder: Beim Zurücksetzen eines Formulars wurden die Werte für ACL-Berechtigungen nicht gelöscht. 5.4
    • Dev Tools: Die standalone-Flag für Anweisungen wurde nicht korrekt angewendet. 5.4
    Quelle: https://community.woltlab.com/…date-woltlab-suite-5-4-8/
    Dieses Plugin erweitert die Datei-Seite der WoltLab Suite: Filebase um die Information "Von x Benutzern heruntergeladen". Per Klick öffnet sich die Liste aller Mitglieder, die diese Datei bereits heruntergeladen haben.
    Die Anzeige kann mit dem Benutzergruppenrecht Kann Liste von Benutzern sehen, die eine Datei heruntergeladen haben gesteuert werden.
    Quelle: https://www.woltlab.com/plugin…he-datei-heruntergeladen/
    Quelle: https://pluginstore.woltlab.co…he-datei-heruntergeladen/
    Quelle: https://www.woltlab.com/plugin…enbank-discord-anbindung/
    Quelle: https://pluginstore.woltlab.co…enbank-discord-anbindung/
